Can't ping using ROAS in Packet Tracer
kkct
Hi, I'm new, configuring a basic ROAS with 2 PCs, 1 switch and 1 router using Packet tracer, I can't ping from one PC to another PC, here is my configuration:
1. PC1 configuration (in vlan 10):
ip address: 192.168.1.1 255.255.255.0
2. PC2 configuration( in vlan 20) :
ip address: 192.168.1.2 255.255.255.0
3. Cisco 2960 Switch configuration:
interface f0/1
switchport access vlan 10
switchport mode access
interface f0/2
switchport access vlan 20
interface g0/1
switchport mode trunk
4. Cisco 2901 Router configuration:
interface g0/1
ip address 192.168.1.3 255.255.255.0
no shutdown
interface g0/1.10
encapsulation dot1q 10
ip address 10.10.10.1 255.255.255.0
interface g0/1.20
encapsulation dot1q 20
ip address 20.20.20.1 255.255.255.0
I can't ping from PC1 to PC2 and vice versa. All the cables are well connected and interfaces up. Did I miss something?
luis_cordova
Hi @kkct ,
Try making these changes:
ip address: 10.10.10.2 255.255.255.0
gateway: 10.10.10.1
ip address: 20.20.20.2 255.255.255.0
gateway: 20.20.20.1
interface f0/1
interface f0/2
interface g0/1
interface g0/1
no ip address
no shutdown
interface g0/1.10
interface g0/1.20
As you can see, the IP parameters of the vlan's pcs must correspond to the address configured in the subinterfaces.
Also, there should not be an IP address in the physical interface, but only in the subinterfaces.
luis_cordova
Hi @kkct ,
gateway: 10.10.10.1
gateway: 20.20.20.1
interface f0/1
interface f0/2
interface g0/1
interface g0/1
no ip address
no shutdown
interface g0/1.10
interface g0/1.20
Thank you very much!
