cannot assign static ip address to lag, cisco switch sf300
tri-hutomo
i cannot assign static ip address to lag or vlan, web browser always lose connectivity
in ipv 4 configuration i was delete the dhcp configuration, but still the same
please explain step by step, because i'm a newbie. and sorry for my bad english
Tom Watts
Hi Tri.the reason you cannot assign an IP to VLAN or LAG is because the switch is in layer 2 mode. First you need to configure the switch in layer 3 mode. This will erase the configuration off the switch. Once that is done, make sure to assign a static IP address to VLAN 1 then you may create additional VLAN and assign IP address to them.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
