SF300 switch cannot detect desktop
ahmed
Hi all,
i've installed switch SF300 48 ports for IP phone environtment, i configured it as guide, if i attach ip phone it works normally,
but when i plug laptop to switch port, it cannot connect to anywhere, then i tried to change native vlan for smartport when detect desktop, but still same problem, i look into smartport properties, there is no desktop detection feature (pic attached)
please advice
7 Replies 7
Tom Watts
Hi Kabiru, host is the desktop connection. But this probably doesn't matter much.
Can you display the port configuration for a port you're connecting your computer to?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
psurampa
Hi Kabiru,
Please let me know the running-configuration of your switch and also can i know what is the OEM(original equiptment manufacturer) of your desktop which you are trying to connect and firmware version of the switch. under administration -->discover LLDP --> LLDPneighbour information were you able to see Desktop connected, If you try disbaling the smart ports and re-configuring the switch also fix the issue but if you still want to configure the switch with smart ports enabled then please attach screen shots of your port configuration settings and running config.
Phanikrishna
ahmed
Hi Tom and Phani,
thanks for your help, i attached the sh run config in the switch also LLDPneigh info, i reproduce the problem use port number 19 which i connect to my laptop (Lenovo). i look into LLDP neigh info, but i only see Gi1 as trunk to another switch, i don't see any port which Phani asked.
1.2.7.76
Please advice,
Kabiru
Switch config :
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.02 11:54:18 =~=~=~=~=~=~=~=~=~=~=~=
   [D   [D   [Dsh run
config-file-header
Switch-lt7
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 7,80,254
exit
voice vlan id 80
voice vlan state auto-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
[0mMore: ,  Quit: q or CTRL+Z, One line:
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname Switch-lt7
ip telnet server
interface vlan 7
name "lantai 7"
no ip address dhcp
interface vlan 254
name console
ip address 192.168.254.17 255.255.255.0
interface fastethernet19
switchport trunk allowed vlan add 7,80
interface fastethernet46
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
macro description ip_phone_desktop
!next command is internal.
macro auto smartport dynamic_type unknown
interface fastethernet47
interface fastethernet48
switchport mode access
switchport access vlan 254
interface gigabitethernet1
switchport trunk allowed vlan add 7,80,254
macro auto enabled
macro auto processing type host enabled
macro auto built-in parameters desktop $max_hosts 10 $native_vlan 7
macro auto built-in parameters host $max_hosts 10 $native_vlan 1
macro auto built-in parameters ip_phone_desktop $max_hosts 10 $native_vlan 7
ip default-gateway 192.168.254.1
Switch-lt7#exit
Ivor Diedricks
Kabiru,
The way the switch learns the connected device is through a dynamic discovery protocol such as CDP (Cisco Discovery Protocol) or LLDP (Link Layer Discovery Protocol). That's how it is learning the attached phones. Unless you specifically installed an app on your laptop which is sending out CDP or LLDP discovery messages, it is not making itself known to the network. That's why the switch does not "see" the laptop.
Ivor
almoncad
Hi Kabiru,
Try disabling smartport and see if this fixes your problem. If not, install the latest firmware (Click Here to download the latest firmware) and let us know if your problem is solved.
ahmed
OK thanks for help, i will try it ASAP when i go to customer
rammahajan
Can anyone please provide me SNMP MIB files for cisco SF 300-48 48-Port 10/100 Managed Switch?
I need it urgent.I am able to get it from cisco site also.
thanks
Ram
