01-21-2017 11:27 AM
I have a SG350-28p managed switch but it worked on L2 layer mode as no router was connected but recently due to change of requirement I have to add a router before it so I need to change the system mode to L3 but to my surprise in web based gui I could not find the "system mode" in administration menu under host name as written in administration guide. Is there any settings that need to be changed to get the system mode visible?
I am novice to this please help me in this. Thanking you in anticipation
02-06-2017 12:49 PM
Same here! We've got dozens of SG300s which have this, but can't find it anywhere on the new SG350?
is it enabled by port instead of the whole switch?
08-16-2017 09:49 AM
i have the same problem, when i purchased the switch and used it for the first ti me this option was available, and it disappeared after i did a firmware upgrade.
is there any extra setting needed to set to enable this again? or this switch now is operating on Layer 3 by default?
04-23-2017 11:59 PM
Same problem. No "System Mode" on the system settings page.
And the command "show system mode" is not recognized on the CLI ...
Was anyone able to find how to change to L3 mode ?
Thanks!
Screenshot below. Running latest Firmware Version (Active Image): 2.2.8.4
