Cant reset the Cisco switch 350
aadel8888
I dont have the username and password for cisco switch 350 and when try to reset it. the switch not perform factory reset and still need username and password (try the default for cisco/cisco) but no luck to open. kindly advice if any has the same issue.
@aadel8888
 How are you factoring reset it?  Do you have console cable?
