01-14-2024 11:02 PM
Can i stack two c9200 using lan ports not stack kits ? If so can someone provide me link with instructions.
thanks !
01-14-2024 11:07 PM
Hello @cherneff
No it is not possible. C9200 series switches typically support stacking using dedicated stack ports.
01-14-2024 11:08 PM
No, it is possible.
01-15-2024 02:21 AM
Cat 9200 do not support Flexstack you think the way,
instead you can do port-bundling - Layer 2 if you like to extend the VLAN (that does not replace stacking technology) - that is option you can have.
01-15-2024 03:11 AM
High end cat 9k series use data port for stackwise virtual
But this sw 9200L dont have this feature
MHM
