Catalyst 3650 Add VLAN to Trunk
danmand
I'm trying to add a newly created VLAN to an existing trunk port.
Logging into the web GUI, I go to CONFIGURATION / PHYSICAL INTERFACES
I then click on port and get a pop up window called Ethernet Interface Settings
Then Port Settings tab
Here's what I see
Switch mode = trunk
Allowed Vlan = Vlan IDs
Vlan IDs = 1,10,22-25,50
When I try to add the new vlan (99) at the end of the 50 I get a message that reads "Default VLANs 1002-1005 can't be modified"
What am I doing wrong?
balaji.bandi
You can follow the below steps and let us know how it goes : (i would suggest to do this steps on command level)
config t
vlan 99
name VLAN99
interface  interface-number x/x   - make sure change this as per your interface
switchport trunk allowed vlan add 99
end
BB
5 Replies 5
AdamF1
Try adding it through the CLI to see if you get the same error.
switchport mode trunk allow vlan add 99
balaji.bandi
config t
vlan 99
name VLAN99
end
BB
Thank you for the suggestions although I was hoping I wouldn't have to do it with the CLI.
About a year ago, I had help from a Cisco Engineer to setup this switch.  It even took him a few days to work out the issues I was having.
I wrote down the user name and password for it, but I guess It only works with the GUI.  It doesn't seem to work when I try to access the CLI.  Different user and password?
From the GUI it should work, Since you mentioned GUI you having issue, other alternative i was suggested to fix the issue.
depends on how you setup the device in the intially.
by any chance you can download the config from GUI, so we can look and suggest.
BB
Thank you so much for you help but I was able to log into the CLI.  I was using SSH instead of Telnet.  Oops.  :)
