CBS 350 & 802.1x & Mac based authentication
henrihoffmann
have a CBS 350 stack and issues with the Mac based authentication, 802.1x authentication with our Radius server works fine. According to the trace, the Radius server receives (in case of a Mac) no packet from the switch. Are there any restrictions. No messages, just "unauthorised", that's all.
How to find the root cause?
Henri
9 Replies 9
balaji.bandi
what Radius server you using ?
What does your 802.1x config look like ?
, just "unauthorised", that's all.  - this message from switch or radius (you may be required to enable debug see more logs )
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-/802_1X_Commands.html#wp3646181654
BB
Hi balaji,
LANCOM build in Radius server, as I mentioned, it works fine for 802.1x, but the CISCO Switch sends not Mac Auth. Pakets to that box, so I think we do not check the anything, as long, I get no packet from the switch.
sh dot1x detailed
Authentication is enabled
Authenticator Global Configuration:
Authenticating Servers: Radius
MAC-Based Authentication:
Type: Eap
Username Groupsize: 12
Username Separator: -
Username case: Lowercase
Password: MD5 checksum
Unauthenticated VLANs:
Guest VLAN: VLAN 4, timeout: immediately
Authentication failure traps are enabled for 802.1x, mac, web
Authentication success traps are disabled
Authentication quiet traps are disabled
Supplicant Global Configuration:
Supplicant Authentication success traps are disabled
Supplicant Authentication failure traps are enabled
gi3/0/1
Authenticator is enabled
Supplicant is disabled
Authenticator Configuration:
Host mode: multi-host
Authentication methods: mac
Port Administrated Status: auto
Guest VLAN: disabled
VLAN Radius Attribute: disabled
Open access: disabled
Server timeout: 30 sec
Port Operational Status: unauthorized
Reauthentication is enabled
Reauthentication period: 3600 sec
Silence period: 0 sec
Quiet period: 60 sec
Interfaces 802.1X-Based Parameters
Tx period: 30 sec
Supplicant timeout: 30 sec
Max req: 2
Authentication success: 0
Authentication fails: 0
Supplicant Configuration:
retry-max: 2
EAP time period: 30
Supplicant Held Period: 60
Henri
KJK99
Level 3
Level 3
@henrihoffmann
Have you set up the RADIUS client in the switch?
Kris K
sure, "802.1x authentication with our Radius server works fine"!
BR
Henri
KJK99
Level 3
Level 3
Yeah, I’ve seen that. You haven’t mentioned explicitly the switch it works with so just checking
Can you toggle between Auto and Force Authorized under 802.1X Authentication >Port Authentication>Edit Port Authentication>Administrative Port Control? You should see some messages in your RADIUS server log when you do that. If those messages are not informative, I don’t know what to say.
My RADIUS server is FreeRADIUS. No issues. The only tricky part was to set the proper format of the username for the server.
My port authentication configuration doesn’t really look different than yours.
#sh dot1x detailed
  Type: Radius
  Username Separator: :
  Username case: Uppercase
  Password: MD5 checksum [snip]
Authentication success traps are enabled for 802.1x, mac
Supplicant Authentication success traps are enabled
gi1
Port Operational Status: authorized
  Tx period: 30 sec
  Max req: 2
Authentication success: 5
Authentication fails: 1
retry-max: 2
EAP time period: 30
Kris K
Hi Kris,
thanks, I do not see such a message in case of Mac Based Auth.. Are there some restriction in conjunction with that, (e.g. Spanning Tree or things like that?).
BR
Henri
KJK99
Level 3
Level 3
It works with STP, but I would make sure Smartport is disabled. Check the RAM Memory log of the switch, too. You should see entries like below.
When authorized: MAC [snip] is authorized on port gi1
When unauthorized: MAC [snip] was rejected on port gi1 due to wrong user name or password in Radius server
Kris K
I configured 802.1x & MAB but I can´t see anything in the radius log form the MS radius. Log on the switch is possible.
Configuration:
SW15-Admin#sh dot1x detailed
Type: Radius
Username Groupsize: 2
Supplicant Authentication failure traps are disabled
gi1
Authentication methods: 802.1x+mac
VLAN Radius Attribute: enabled, static
Port Operational Status: unauthorized*
* Port is down or not present
Reauthentication is disabled
Tx period: 30 sec
Max req: 2
Authentication fails: 5
retry-max: 2
EAP time period: 30
Uo to now I just checked MAB
