CBS 350 SNMP - do these switches support all OIDS? errDisable?
redgasgiant
I want to monitor when ports go into error disable due to BPDU guard.
On my test bench I can put my cbs350 into the situation and see that a port is disabled
but I can't seem to SNMPWALK the OID. Does the small business series even support this?
info@zabbix:~$ snmpwalk -v 2c -c public 10.xxx.xxx.xxx 1.3.6.1.4.1.9.9.548.1.3.1.1.2
SNMPv2-SMI::enterprises.9.9.548.1.3.1.1.2 = No Such Object available on this agent at this OID
I'm a OID and MIB noob and using this https://www.reddit.com/r/zabbix/comments/virx4m/monitoring_of_errdisabled_cause_by_linkflap/ as a starting point.
balaji.bandi
CBS350 do not support all SNMP features as i see, but check there are some MIB you need to download and test it.
https://software.cisco.com/download/home/286282293/type/283415684/release/2.0.0.73
BB
redgasgiant
Thanks BB, I have downloaded the MIB files... But I have to be honest.. I do not know what to do with them.  I have copied them into my /usr/share/snmp/mibs  on the machine I used to snmpwalk. But again, I have no idea what I'm doing!
