CBS220 lots of "invalid RX" IGMP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-02-2024 07:17 PM
So I have a flat network with a CBS220 as the main switch off of the router and a second CBS250-T-D that is powered by the 220. I have enabled IGMP snooping and enabled the IGMP querier on the 220, and enabled IGMP snooping (without querier) on the 250. In the 220 CLI i see large amounts of "Invalid RX" packets increasing regularly:
IGMP Snooping Status -------------------- Snooping : Enabled Report Suppression : Enabled Operation Version : v3 Forward Method : mac Unknown Multicast Action : Flood Packet Statistics Total RX : 85830 Valid RX : 16211 Invalid RX : 69436 Other RX : 0 Leave RX : 5 Report RX : 16206 General Query RX : 0 Specail Group Query RX : 0 Specail Group & Source Query RX : 0 Leave TX : 0 Report TX : 15910 General Query TX : 115055 Specail Group Query TX : 55 Specail Group & Source Query TX : 0
I THINK multicast is working, as I have 2 Sonos devices that join to the 239.255.255.250 group, and the web interface correctly identifies which ethernet ports they are connected to. Also when I start avahi-daemon on my Linux PC it will join the group as well, and I can ping the group address and I get unicast replies back from both of the Sonos.
So what's going on with the invalids? Thanks in advance.
- Labels:
Small Business Switches
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2024 07:20 PM
@train_wreck hi, this can be due to faulty cable/SFP. can you try #sh interface and see if you can find any CRC errors..?
Good luck
KB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2024 07:21 PM
Zero errors, and the copper-port-test feature reports all good.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2024 07:29 PM - edited 02-02-2024 07:30 PM
Hmm well actually there are 0 CRC but it looks like a ton of "input errors"? This is from the CLI on the 220, g/2 is connected to the 250
GigabitEthernet2 is up
Hardware is Gigabit Ethernet
Auto-duplex, Auto-speed, media type is Copper
flow-control is off
back-pressure is enabled
8083250 packets input, 1649346442 bytes, 0 throttles
Received 23556 broadcasts (1059121 multicasts)
1 runts, 3892195 giants, 0 throttles
3892449 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
1059121 multicast, 0 pause input
16958192 packets output, 15051713059 bytes, 0 underrun
0 PAUSE output
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-03-2024 09:45 AM
Maybe try to do a wireshark, and look for IGMP traffic and/or that potentially can increase those counters. No sure if you doing filtering on the IGMPv3, epdening on the capabilities of that CBS.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-07-2024 07:21 PM
I can see during a tcpdump that the counter increases whenever any multicast traffic is received. Group query traffic will do it, and the Sonos periodically send discovery packets UDP dport 1900 to the multicast address, and that traffic will increase the counter as well. This is all IGMPv2, no filtering. Like I said, multicast seems to be operational, so it may just be a reporting bug. I can post decrypts of the multicast traffic if requested. ("-vX" switch in tcpdump)
