12-09-2022 02:03 PM - edited 12-09-2022 02:30 PM
Hello there,
I have struggling to locate DHCP Snooping options with this model. Even the Administration guide gives info for CBS250 series to support DHCP Snooping.
Anyone with any info about this option.
12-09-2022 02:18 PM - edited 12-09-2022 02:18 PM
how about here :
check video also helpful
12-09-2022 02:29 PM - edited 12-09-2022 02:38 PM
12-10-2022 12:44 PM
I don't know how it is possible to give available commands in CLI Guide for the series but in reality it could not be setup like you have cross-reference...
12-10-2022 03:08 PM
even i looked lower model 220 on the emulator I can see that option
check firmware and upgrade to 2.0.0.17
12-10-2022 10:05 PM
Yeah I looked in the emulator also, but after tried the first available old firmware for the cbs250. The feature is missing???
I am shocked how that is possible?
The unit will be RMA-ed and swapped for CBS220 series. Hope that will solve the need.
12-11-2022 11:46 AM
Sure if that missing then you need to upgrade the version support or contact SMB TAC
