11-26-2022 07:04 AM
Got a brand new CBS250-48PP-4G and something seems to be wrong, because the switch is too loud. Datasheet says ~ 37 dBA, my own measurement says > 50 dBA while nothing is attached, all ports are unused. Did I get a damaged device or do I miss anything?
11-26-2022 09:52 AM
- Probably needs to be replaced (indeed)
M.
11-26-2022 12:16 PM
Thx. Do you know in which distance to the switch the measurement of the 37 dBA was done?
11-27-2022 04:56 AM
standard for measuring dbA would be at a metre distance. Sounds like you have a faulty one but if your that sensitive perhaps look at the fanless variants and see if they will meet your poe need. might take two switches such as the 24P or 24pp to achieve the same but they should be silent
11-27-2022 06:01 AM
Thanks a lot. Already have a fanless 24P-4G, which I want to replace by the 48PP-4G. The ~ 50 dBA are not the problem in general, but I just want to prevent having a brand new but faulty device. I’ve just ordered another one and will return the existing one.
