Showing results forĀ
Search instead forĀ
Did you mean:Ā
Failed to SSH to Cisco SMB SG-350 switches using Ansible
Hetch
I'm trying to use Ansible to configure Cisco SMB SG-350 switches , but its failing to SSH, when trying to gather facts. the error message appears is:
fatal: [10.75.2.2]: FAILED! => {"changed": false, "msg": "Failed to authenticate: ('Bad authentication type', ['']) (allowed_types=[''])"}
[hesham.samir@ncm1 u000]$ ansible-playbook -i routers_switches gather_facts_switches.yml
PLAY [Gather Facts] ****************************************************************************************************************************************************************************************
TASK [CiscoSMB - Gather Facts - subset default] ************************************************************************************************************************************************************
[WARNING]: ansible-pylibssh not installed, falling back to paramiko
fatal: [10.69.13.2]: FAILED! => {"changed": false, "msg": "Failed to authenticate: ('Bad authentication type', ['']) (allowed_types=[''])"}
I can SSH directly to the switches with no issues. did anyone see issue before?
Thanks in advance for help.
6 Replies 6
balaji.bandi
post YML file.
BB
Hetch
Below is the playbook YML file.
I'm using ansible_network_os: qaxi.ciscosmb.ciscosmb in the host file.
- name: Gather Facts
  gather_facts: no
  hosts: switches
  vars:
    - configs_dir: configs
  tasks:
    # Collect data
    - name: CiscoSMB - Gather Facts - subset default
      qaxi.ciscosmb.ciscosmb_facts:
        gather_subset:
          - default
      # when: ansible_network_os == 'qaxi.ciscosmb.ciscosmb'
    - name: CiscoSMB - Gather Facts - subset config
        gather_subset:
          - config
    - name: Create configuration directory
      local_action: file path={{ configs_dir }} state=directory
      run_once: true
      check_mode: no
      changed_when: no
    - name: Save running config
      local_action: copy content={{ ansible_net_config }} dest={{ configs_dir }}/{{ inventory_hostname }}_net_config
Aleksandra Dargiel
Please try to enable password authentication on the switch:
Security > SSH server > SSH user authentication >
Hetch
Hi Aleksandra,
Thanks for your reply. in fact GUI is disabled, but SSH is enabled on the switch. also, I can SSH directly from the Ansible Server, but Ansible playbook cannot do. below is the output from direct SSH.
[root@srv1]$ ssh user1@10.69.13.2
This node is property of
Unauthorized Access Prohibited. Access will be monitored
User Name:user1
Password:*************
S01#sh management access-class
Management access-class is enabled, using access-list MGMT
S01#sh management access-list
MGMT
permit ip-source 10.0.125.0 mask 255.255.255.0 service ssh
permit ip-source 10.69.13.0 mask 255.255.255.0 service ssh
permit ip-source 192.168.211.16 mask 255.255.255.240 service ssh
permit ip-source 10.172.1.0 mask 255.255.255.0 service ssh
permit ip-source 192.168.211.16 mask 255.255.255.240 service telnet
permit ip-source 10.172.1.0 mask 255.255.255.0 service telnet
permit ip-source 10.0.125.0 mask 255.255.255.0 service telnet
! (Note: all other access implicitly denied)
console-only
deny
Aleksandra Dargiel
I see... and is it working when no MGM ACL?
Hetch
Hi Aleksandra .. good point.
I tried removing the MGMT ACL, but it gave me the same results.
however, I found something interesting, when I try to SSH directly to the swicth, it give a propmt to enter my username again (although I already entered it in the SSH command). I suspect this may cause some problems with Ansible not able to login to the switch.
If I tried to enable  password-auth on the switch (ip ssh password-auth command), would this solve the problem and casue the switch to prompt only for the password ?
Thanks & Regards,
