CBS250 ACL - wildcard, whats the difference
Hubsi-Smith
actually I think I have an understanding problem with ACL on the CBS250 series.
I use a DHCP Server with IP: 192.168.100.65/27
When I set this input rule:
permit udp any any 192.168.100.65 0.0.0.0 67-68 ace-priority 1
The client cannot recieve the DHCP server.
When I change the input rule to:
permit udp any any 192.168.100.65 255.255.255.255 67-68 ace-priority 1
The client recieve an IP address.
Why thought always that 0.0.0.0 is for wildcard the host. Is there an special for the cbs250 series?
Access-list most frequently uses host/mask nottation. Usually routing protocol like OSPF use wiildcard mask and some newer devices now prefer /XX
You could try 0.0.0.255  which means: must match 192.168.100 but anything in the last octect.
