02-27-2023 04:45 AM
Hi, I've recently acquired a cbs350.
I've connected a couple of Poe devices (to he specific a glensound express ip MkII, a glensound paradiso lite and a glensound vita), but they won't turn on. I've had them working with other PoE switches, but I can't find a way to have them working with the new one.
I was wandering if maybe I was missing some settings, or compatibility issues...
02-27-2023 08:21 AM
- What are the POE (power) requirements for these devices ?
M.
02-27-2023 03:24 PM
as per the device need standard PoE , doe the CBS provide any other device PoE ? if yes
check show power inline (you have enough PoE to support)
also, make sure you set up low PoE power to make it work.
power inline priority {critical | high | low}
