CBS350 connect to cloud
EngAbuzalata
hello there someone tells me that I can  connect CBS switches series to cloud is this true is there a new dashboard for CBS
if there how can i connect the switches to cloud
2 Accepted Solutions
balaji.bandi
check below : (if you looking for management)  - the switch needs to be exposed to internet. (means your firewall should allow on-prem to cloud)
https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html
BB
yes it is. you need to have virtualized server to install this or you can use AWS to install. after that devices needs to bind with server. check below datasheet
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/business-dashboard/nb-06-bus-dashboard-ds-cte-en.html
Good luck
KB
6 Replies 6
balaji.bandi
BB
Good luck
KB
how can I access the dashboard and after installing the VM how to add the inventory to dashboard,the datasheet is not helpful
Ezzy
Thank you for everyone tried to help. I have the same issue. I read the datasheet but seems not helpful. the last link is not working.
