CBS350 Firmware Upload failing
efries_wy
I have https firmware uploads failing on multiple switches at different clients.  The logs show a generic "the copy operation failed".  Two of the switches:
CBS350-24p-4G | firmware v3.2.0.84
CBS350-24p-4x | firmware v3.3.0.16
An upload of the same firmware file v3.5.0.26 upload works successfully using ssh and tftp.
I have tried:
  • Confirming the hash and re-downloading the firmware.
  • Different browsers.
  • 3 different firmware versions:
    • 3.3.0.16
    • 3.4.0.17
    • 3.5.0.26
  • Moving the downloaded file to a local, non-redirected, not OneDrive, path.
  • Disabling http so login and upload are definitely via https.
I would appreciate any ideas, upgrading via tftp will be much more time intensive vs https.
Thank you.
Mark Elsen
  - Check access and error logs on (from) the remote web server, look for success on transfer of the intended files (firmware) or not (e.g.)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
efries_wy
Hmm, this is an https upload via browser that is failing, there is no remote web server, not sure what you are referring to?
- If there is an upload through http/https  then by definition it must come from a remote webserver, but I forgot that this may be from Cisco directly, I noticed below that you can also upload through  a local file. Does that work ?
     Meaning downloading the firmware first in that case.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
efries_wy
Steps taken:
  • Logon to local workstation on same network as CBS350 switch.
  • Download firmware from Cisco.com to local workstation.
    • Download is from remote webserver, this is successful.
    • Confirm file hash matches.
    • Login to Cisco CBS350 via https
      • Upload firmware file from local workstation via https to CBS350.
      • Upload fails with a generic error.
  • Login to same CBS350 via ssh from same workstation.
    • Upload same firmware file via tftp.
    • this is successful
