CBS350 not reachable after a certain device is connected
kaifabian
We are using the attached configuration file.
When now a certain device is connected to the switch, the message appears in the webinterface:
afterwards the switch is not reachable anymore.
if this device is disconnected and the switch rebooted it is back to normal and working.
What am i missing here?
12 Replies 12
marce1000
  - It looks like the particular device does networking and or participates in spanning-tree , hence making the SG unreachable (possibly) , if that is not intended set the port to host mode  (access port).
 M.
my vlan mode is set as Access is this what you mean? otherwise where can i find the configuration you mentioned?
            - No , what I was essentially saying is  , what kind of device and or model is this ?
 M.
it is an aes67 audio streamer.
 - Set the particular port to access mode , with the CLI command :  switchport mode access
 M.
it is set as access - as you suggested but still same issue.
this is the status on the log console:
                - Post the complete configuration from the running-config of the particular port.
 M.
You can find the current configuration attached.
        - Which particular port (number) is the aes67 connected too ?
 M.
Currently it is connected to port 1.
 - You haven't provided the port 1 configuration  , in the earlier running-config.txt , post complete running-config
 M.
