06-29-2021 12:14 PM
With the CBS350 replacing the SG350; will the smaller (8-port) units support being powered via PoE, PoE+, or PoE 60W? If so, will they also support any degree of PoE passthrough.
06-30-2021 12:32 AM
- Have a look at the datasheet (search for 'Power over Ethernet') :
M.
06-30-2021 02:04 AM
Hi there,
60W PoE is supported on select RJ-45 network ports on select models (https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html Power over Ethernet (PoE) section). Currently, we don't offer PoE powered device and PoE passthrough functionality with the CBS350 series switches, however, there might be upcoming models with that support.
Martin
