CBS350, private VLAN, DHCP
KJK99
Beginner
Beginner
I have a CBS350 switch that is set up to do inter-VLAN routing and provide DHCP addresses. That has been working without any issues for quite a while. Recently, I have created a private VLAN on it which is working okay except for one issue. I cannot get DHCP addresses for isolated or community hosts. They do work with static IP addresses though and a device connected to the promiscuous port can obtain a DHCP address.
Have anybody been able to configure a CBS350 switch so it issues DHCP addresses to isolated or community hosts in a private VLAN?
Kris K
9 Replies 9
marce1000
  - Are you seeing DHCP requests arriving from the particular hosts in the logs of the DHCP server ? Also best to disable the Smartport feature ; review this document :
                                 https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt-2797-smartport-best-practices-CBS.html
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
 When you created the Private vlan, did you assign IP address for that or you created only in Layer 2?
If you create only Layer2 vlan and this is a private vlan, I believe DHCP request will not reach the DHCP service on the switch unless you assign IP to this Vlan.
KJK99
Beginner
Beginner
@marce1000
I do not see any DHCP messages in the switch’s log. The logging level is set to ‘debug’. The Smartport feature is disabled. If I connect a device with a DHCP server to the promiscuous port, the isolated and community hosts can get DHCP addresses from it. The private VLAN works okay except for that DHCP issue with the switch’s internal DHCP server.
@Flavio Miranda
The primary VLAN has a SVI set up and the routing is working. Anyways, the DHCP server on those switches works even if they are configured as L2.
Kris K
I am confuse. You said:
"Recently, I have created a private VLAN on it which is working okay except for one issue. I cannot get DHCP addresses for isolated or community hosts."
So,  do you have IP address on the private vlan?
                             >...I do not see any DHCP messages in the switch’s log
   The question (also) was whether you see any requests arriving from these hosts in the dhcp sever   logs ,
 M>
The DHCP server log on CBS350? I wish there was one.
Kris K
                            >...The DHCP server log on CBS350? I with there was one.
          Sorry I thought you were using an external dhcp server , (not on the CBS) , actually that might be a good thing to try (and or test)  a setup where the DHCP server is 'not local' (so to speak) ,
 M.
KJK99
Beginner
Beginner
@Flavio Miranda
What do you mean? A private VLAN is actually a group of three types of VLANs, one primary and two secondary (isolated and community). I do not have any issue with the primary one. DHCP is working fine for it. DHCP for the secondary one is the issue and only with the switch's internal DHCP server.
Kris K
Got it. If you have no problem on the Primary vlan enable DHCP snooping on the
primary VLAN, it is propagated to the secondary.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
