CBS350 series firmware files
Niabali
On Cisco's software download site it lists the different switch models (CBS350-8P-E-2G, CBS350-24P-4G, CBS350-48P-4g, Etc.) The downloaded bin file for different switch models have the same file name and file size.  Can you download once and use the same image on 8, 16, 24 or 48 port models?
@Niabali hi, yes correct. most of the time same model have same file even different port counts. but its different between different series. always make sure check software download website and confirm without guessing to avoid unexpected results :).
Good luck
KB
 Different pprt number is not Different model actually. They can be considered the same model and thats why the software is the same.  For example CBS250 Would be a different model.
Good luck
KB
