%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected
htech460647724
Hello Guys,
I'm encounter the following error always with one of my new cisco switch sg250 that i just configured for my LAN.
I just need some help of how can i solve. Is the following error can cause any networking traffic drops or not. please help.
03-Sep-2021 13:23:41 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi15.
03-Sep-2021 13:22:30 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi16.
03-Sep-2021 13:19:05 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi10.
03-Sep-2021 13:18:41 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi15.
03-Sep-2021 13:17:30 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi16.
03-Sep-2021 13:14:05 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi10.
03-Sep-2021 13:13:41 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi15.
03-Sep-2021 13:12:30 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi16.
03-Sep-2021 13:09:05 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi10.
03-Sep-2021 13:08:41 :%CDP-W-NATIVE_VLAN_MISMATCH: Native VLAN mismatch detected on interface gi15.
5 Replies 5
balaji.bandi
if this is trunk link - You make sure that the native VLAN is the same on both sides of the links, If not you see those error messages.
BB
Thanks for your response. could you please provide any steps. your help will much appreciated. thanks
Yes. they are all trunk lines. could you please help
check what is the other side native VLAN, so make sure both should match.
switchport trunk native vlan  X  ( X should match both the side to eliminate that error)
BB
dmancini1983
Hola, yo encontré la solución, en los puertos troncales donde tienes otra vlan nativa, para los equipos CB220 tiene que estar la interfaz del puerto configurada en General, no en trunk y pasar la VLan 1 como Untagged y la vlan que tengas como acceso marcarla como Untagged y PVID. Con eso no pasaría mas la notica de Mismacth.
