05-10-2024 06:24 AM
Hi All,
Please, i have a SMB network installation for a small enterprise of 15-20 users, and i am planning to use Catalyst 1000 Series Switch and Cisco 900 Series Integrated Services Router.
Please is this a good devices? if not suggest for me others.
Solved! Go to Solution.
05-10-2024 06:33 AM
@bilalmekati hello, those selected models are good. also you can check cisco CBS series for switches.
05-10-2024 06:58 AM
Small Business Switch are suggested for low cost and features.
make sure you check the end fo life notes before you buying any model
Other hand check Meraki switches it got nice dashboard free managing any where from world.
05-10-2024 06:33 AM
05-10-2024 06:48 AM
Thanks mate, i really appreciate your comment.
05-10-2024 06:58 AM
05-10-2024 07:04 AM
OK, Thanks bro
