01-04-2017 09:18 PM
I have setup a link aggregation between 2 Cisco SG300 network switch. I had assign port 1 and port 2 (both are Gigabit port) as a member of LAG1. From the Cisco switch GUI,it is shown that the both port is an active member. In this case, will the LAG1 show the total link speed is 2Gbps? Can we see the LAG speed from the Cisco switch GUI? Please advise
01-05-2017 06:29 AM
I haven't got an SG300 in front of me at the moment but on the Catalyst you can use the following CLI command to view the Port Channel bandwith:
#show interface po1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is
Description:
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Unsure if this works on the SG300.
01-05-2017 05:43 PM
Unfortunately, I cannot get the same result using SG300. Below is the output from SG300
#show interfaces Port-Channel 1
Load balancing: src-dst-mac
Gathering information...
Channel Ports
Po1 Active: gi25-26
