12-03-2017 09:28 AM - edited 03-21-2019 11:18 AM
Good morning all,
I am going to start off with what I am trying to accomplish with my switch. I am using a 3750-48TS for my home lab. I am fairly familiar with cisco equipment, but have never upgraded a switch. Originally I had the switch configured with all my vlans, but I found that the stock ios didn't support ssh and i was told that I would need upgrade the ios, but with this switch I have I found that ram/flash was onboard so I had to delete the current ios.(Original image: c3750-ipbase-mz.122-25.SEE1.bin)
This part wasn't an issue and went fine. The first image file I tried to load would spite out a string similar to this: !!!!!!!!!!!O!!!!!!!!!!!OO!!!!!!!!!!!!!!!O!!!!!!!! and so on.. at it would say device was out of space (c3750-ipservicesk9-mz.150-2.SE11.bin).
I took a step back and did some research and found that the image file was most likely to large. I stepped down to the current image I have uploaded to the switch now which is: (c3750-ipservicesk9-mz.122-55.SE12.bin). Now with this image I am finding I can't log into the switch from the browser i get this message: http://<switch IP> is requesting your username and password. The site says: “level_15_access”
In the end I am just trying to find out how to login and manage the switch from the browser and what is the most current image I can upgrade this switch to that . I am including my sho version and thanks again for any suggestions.
CoreSwitch#sho ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE12, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:29 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
CoreSwitch uptime is 17 hours, 27 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE12/c3750-ipservicesk9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-48TS (PowerPC405) processor (revision M0) with 131072K bytes of memory.
Processor board ID CAT1027ZMHY
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:18:B9:2E:49:80
Motherboard assembly number : 73-9680-10
Power supply part number : 341-0028-02
Motherboard serial number : CAT102763ZM
Power supply serial number : DTH10232BBF
Model revision number : M0
Motherboard revision number : A0
Model number : WS-C3750-48TS-S
System serial number : CAT1027ZMHY
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT102681VC
Top Assembly Part Number : 800-25854-02
Top Assembly Revision Number : D0
Version ID : V05
CLEI Code Number : CNMV300CRE
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48TS 12.2(55)SE12 C3750-IPSERVICESK9-M
Configuration register is 0xF
Solved! Go to Solution.
12-03-2017 12:11 PM
12-03-2017 12:11 PM
12-03-2017 01:30 PM
Thank you for that solution Leo. I kinda figured that would be the case. So do you have any idea about the web login? Why it is asking me for a username and password? Is that something I wont beable to get around?
12-03-2017 01:31 PM
Thank you for that solution Leo. I kinda figured that would be the case. So do you have any idea about the web login? Why it is asking me for a username and password? Is that something I wont be able to get around?
12-03-2017 05:41 PM
