Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 960 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5717 Views
  • 1 replies
  • 16 Helpful votes
Hello,   I have a couple of question about the SG300, I know it has ip routing enabled by default, My question is which are the considerations to create intervlan routing through router-on-a-stick scheme.  I think it is a little bit different like th...
Resolved! SG500 Stacking
I am about to stack a SG500-28 switch to an existing SG500-28.  Both are in native stack mode.  Will it reboot the exisiting SG500-28 that is in production?  Do I need to plan for downtime for this?
SuperIT by Level 1
  • 1111 Views
  • 2 replies
Model: SG200-08Config:Port 1 - 5 VLAN 1 UnTagged Member, VPID 1 (defult config)Port 6 - VLAN 99 Tagged Member, VLAN 1 Untagged Member, VPID 1 (default)Port 7 - VLAN 99 UnTagged Member, VPID 99Port 8 - VLAN 99 UnTagged Member, VPID 99Port 8 Tx & RX Mi...
NOYB2NOYB by Level 1
  • 6530 Views
  • 27 replies
I purchased an SG300-10 with hopes of breaking my network out into 3 VLANs that can intercommunicate for LAN traffic and send internet traffic out through my NETGEAR Nighthawk X6 R8000. My first attempt was as follows: Put the switch in L3 mode.Build...
Hi, We have Cisco SG500X-48 and SG550XG-24F, and we're using the the 10Gb SR modules. When we light the fiber with these modules, we get the error on the SG500X-48. I actually have a set of SG550XG's (550XG-8F8T)  that light up fine between the two w...
athorn001 by Level 1
  • 4475 Views
  • 5 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
