Cisco CBS350-48T-4X for Enterprise use
Halfeez92
Recently we bought a CBS350-48T-4X for Enterprise use. Sometimes the switch will become lag and the ping will spike to a high latency even pinging to the local gateway. We also did a cpu utilization command and surprisingly it shows almost to 100% even after a few minutes running.
I just want to ask, is this switch capable for Enterprise use? Despite of having an 800Mhz CPU and just 512 DRAM? Thanks
CBS350 designed for SMB market with cheaper options. i recommend catalyst models for mid and large enterprises for high reliability and performance requirements.
Good luck
KB
