Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3277 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4816 Views
  • 1 replies
  • 16 Helpful votes
I have a new stack unit that looks to be having some issues with PoE. On one of the ports, I can see the following error message:"ESG-ST9#show power inline GigabitEthernet1/0/1 Interface Admin Oper Power (W) Class Device Priority ---------- ---------...
Gvs22748 by Level 1
  • 453 Views
  • 0 replies
On Cisco's software download site it lists the different switch models (CBS350-8P-E-2G, CBS350-24P-4G, CBS350-48P-4g, Etc.) The downloaded bin file for different switch models have the same file name and file size.  Can you download once and use the ...
Niabali by Level 1
  • 1536 Views
  • 2 replies
hii am looking for SG300-28MP 28-Port Gigabit PoE Managed Switch firmware all i can find is SG300-28MP 28-Port Gigabit max  PoE Managed Switch firmware so what should i do?
blue676 by Level 1
  • 565 Views
  • 4 replies
Hello,I am running a SG350-10MP switch. I have noted that sometimes there are issues with my DHCP/IPv4 Address assignment. I can see in my logs that error: %DHCP-F-HASH: Failed insert to DHCPP_alloc_hash_id hash table in function DHCPP_add_addr_from_...
chrisse by Level 1
  • 798 Views
  • 6 replies
Hi all,I have some problems setting up my WLC2504 with a SG300 Switch configured as a Layer3 Router.Basically, I have followed the tutorial I found on this site.What I have done to both devices, is listed in the step-by-step documents that are attach...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
