10-15-2015 09:02 PM
Anybody knows how many actually devices can be added in the community and manage through CNS version 6 ? I have read on cisco website that Cisco Network Assistant can support up to 40 devices in the community I am not sure if it was for earlier version CNA 5.0 as the link http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/network-assistant/product_data_sheet0900aecd8068820a.html shows that it for 40 or fewer switches while looking into the data sheet of version CNA 6.1 it also mentions community limitation to 40 devices while the following link http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/network-assistant/datasheet-c78-730210.html shows that it for 40 or fewer switches. Will be looking forward to seeing the your replies.
Waydee
Solved! Go to Solution.
10-20-2015 01:22 AM
hi Waydee
please refer to Release Notes for Cisco Network Assistant 6.0 and Later where you can find all changes. In summary community limitations are same (max 40 devices) in comparison to older version (5) of CNA.
10-20-2015 01:22 AM
hi Waydee
