Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3658 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5343 Views
  • 1 replies
  • 16 Helpful votes
I installed my SG300-10 just after my router.  I hooked up the CAT5E cables and waited until I had internet.  Then I tried to login to 192.168.1.254.  I Get "This webpage is not available".  I looked at my router to see what is connected and I do not...
smylrea77 by Level 1
  • 400 Views
  • 2 replies
I need to backup the configuration of my switch in a server file, but I want all those shows in a single file, does anyone knows a way to make it possible, I mean instead of doing this .... cli show run | redirect tftp://10.1.1.1/Backup-config_1.1...
badboy_84 by Level 1
  • 463 Views
  • 0 replies
I have a question about typing up an ACL and how to allow one website but block another with my sg300-52 switch. The website I want to block is youtube.com but I want to allow maps.google.com or anything else besides youtube. Now if I do a nslookup...
Hello, We are having issues powering Axis P1428-E cameras using SG110-24HP switch (24 ports, of which 12 are PoE ports, total PoE budget 100W). We tested and camera works OK in middle PoE ports (3, 4, 15, 16). Other PoE ports power a camera a for a f...
I just downloaded LAN BASE WITH WEB BASED DEV MGR  c2960-lanbasek9-tar.122-55.SE10.tar and loaded it into the flash. Then pointed the boot to it in the subdirectory. dir flash:Directory of flash:/     2  -rwx        1980  Feb 28 1993 16:02:22 -08:00 ...
techcoora by Level 1
  • 14785 Views
  • 6 replies
Hello, I have Cisco Small Business SF300 switch. CLI is more or less similar to IOS, but I can't seem to figure out how to PIPE the output of the command like in IOS: "show log | i fa48". I was wondering if the software on SF300 switches completely l...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
