I would to change management vlan on sg200-08 switch, so created in switch vlan 100, my port ge1 which is uplink to other switch is configured as trunk, then on Management ipv4 interface I choosed vlan 100 assignet IP, netmask and gateway correctly as my vlan 100 have. But after that I lost connection to switch, even in local network I cannot ping it.
I do not want change default vlan (1) on that switch, because on my network I use vlan 1 as native, I want to only access switch on management vlan 100 address. How to do that?
