Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 85 Views
  • 0 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5469 Views
  • 1 replies
  • 16 Helpful votes
I have a customer who is interested in spanning three live traffic ports into one span port.  I realize there is a possibility of dropping packets due to performance but I'm curious if this is even technically possible due to the limitation?Thanks fo...
johnk by Level 1
  • 868 Views
  • 1 replies
Hello, I can't update my SG200-18 from 1.3.7.xx to the latest firmware 1.4.0.88. I downloaded the firmware package from Cisco and tried to install it to my device via https and tftp. On both methods the copying of the image stops at nearly 7mb and I ...
d.streese by Level 1
  • 42018 Views
  • 7 replies
  • 10 Helpful votes
I have a switch that will intermittently load up and not have an RSA key loaded into it's configuration.  We are sure that every time it is generated, we save the configuration and reload to ensure that it remains.  A few days later, the key will be ...
TI2491 by Level 1
  • 863 Views
  • 3 replies
I'll be working to recover an administrator password of a switch specifically cisco sg 350 - 28 without any effect / changes in the other configuration. I've tried to consider a solution stating in the two (2) given link 1. https://community.cisco.co...
KaMaLoRa by Level 1
  • 4755 Views
  • 0 replies
I have a cisco 7821 phone I attached a plantronics cs540 headset with a Plantronics 38350-13APC-43 electronic hook switch selector. Everything works fine for 15 seconds then the headset is powered off. Plantronics say that there is a software switch ...
Resolved! SG220-26 VLANS
Excuse the newbie in me, VLANS are new to me and I decided to create them for the pure reason of security.  With all the devices around these days, Echo Dots and so forth, I want these off of my regular network and put into a Virtual Network.   I hav...
I am trying to setup a layer 3 switch at my daughter's real estate business.  I cannot seem to setup a static route on my SG500X-24 switch.  I am getting an error message "Only a directly connected router can be defined as the gateway"  which is what...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
