SG220-50 via DHCP server on DC Issuse
voducthoitc
Dear,
I have been buy Switch SG220-50. When I setup it to my network. Some Issue about DHCP server .
I have DHCP server on Domain Controller. With two scope.
1. Scope ip: 10.60.1.0 : When my laptop, pc connect to the network via cable to SG220, the laptop, pc can not release IP from DHCP server , but when I set static IP for laptop: 10.60.1.100 it work.
2. Scope ip : 10.60.2.0 : When my laptop, pc connect to the network via cable to SG220, the laptop, pc connected and work good, but time to release ip long tim ( about 1 munites0.
Two scope work good via orther switch .
Please help me, how about with scope 10.60.1.0 via SG220.
Jaderson Pessoa
Hello voducthoitc,
I need more information and i can help you.
Please, provide output from sg220
show running-config
Which ip address is the gateway for these networks?
For exemple:
for network 10.60.1.0: gateway is 10.60.1.1
for network 10.60.2.0: gateway is 10.60.2.1
Could you provide it?
Thanks in advance.
Jaderson Pessoa
*** Rate All Helpful Responses ***
dear,
This switch layer 2, It's just have IP managerment. IP auto get infor from the network.
When I connect other network ( not 10.60.1.0), It's relaese ip from DHCP server of this network.
But, only the network 10.60.1.0 could not have ip and not effect to any device (laptop, pc) connect via SG220.
Try test with orther network from wifi accesspoint network 192.168.0.0 via SG220 work good .
Something wrong? :(
Great,
Good lucky ^^
Jaderson Pessoa
Dear,
I fixed.
I must disable Spanning Tree State ( defaults: enable). So this switch stupid
thanks so much.
Tho
