CISCO SG-300 sending packets out all ports like a HUB
Tud
Hi All
I have an SG-300-52, I have been having an issue when there is large traffic on the network everything will gring to a halt
After running packet captures on one of the hosts I see packets too and from all hosts on the network (not just broadcast packets, but packets too and from specific hosts) are sent to my capture host.  I ran a file transfer betrween to other hosts, and all the packets appeared in the capture log on the capture host
I have upgraded to latest firmware version 1.3.0.62 and this made no difference at all
my config is out of the box config, so all ports are configured in trunk mode and part of the default VLAN 1
it seems that soon as a packet enters this switch is it is sent out all ports
the behaviour stays the same after a reboot
any ideas on why this would be happening?
Thanks for your help
9 Replies 9
Unless you are doing any Vlan trunking, you need to setup switchport mode access on the ports instead of trunking. Also, you should setup spanning-tree portfast on interfaces that connect to computers or other devices...DO NO use spanning-tree portfast on any ports connecting to a router or another switch.
Hope this helps!
RIchard
Thanks, I have changed all the ports to access mode and this seems to have made no difference, all packets are still getting sent out all ports
even though they were in trunk mode the should not have been behaving that way either
any other ideas?
I would put the switch in routed mode, which makes it a layer 3 switch. When you do this, it will wipe your configuration, so if you try this, backup your switch first.
Before you do that, if you would upload a plain text running configuration of your switch, I will take a look at it to get a better idea of what is going on.
Richard
Hi, I will try and change to layer 3 mode and let you know what happens, my running and startup config are below, I left the certifcates off the end to save some space in the thread
config-file-header
switch121a57
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator plaintext
voice vlan oui-table add 0001e3
Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switch121a57
username cisco password encrypted
3b14f3ff97862972e3b576a0275053f86554eb1a privilege 15
username fwadmin password encrypted 3b14f3ff97862972e3b576a0275053f86554eb1a privilege 15
interface vlan 1
ip
address 10.20.2.246 255.255.255.0
no ip address dhcp
interface gigabitethernet1
interface gigabitethernet2
interface
gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface
gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface
gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface
gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface
gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface
gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface
gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface
gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface
gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface
gigabitethernet30
interface gigabitethernet31
interface gigabitethernet32
interface
gigabitethernet33
interface gigabitethernet34
interface gigabitethernet35
interface
gigabitethernet36
interface gigabitethernet37
interface gigabitethernet38
interface
gigabitethernet39
interface gigabitethernet40
interface gigabitethernet41
interface
gigabitethernet42
interface gigabitethernet43
interface gigabitethernet44
interface
gigabitethernet45
interface gigabitethernet46
interface gigabitethernet47
interface
gigabitethernet48
interface gigabitethernet49
interface gigabitethernet50
interface
gigabitethernet51
interface gigabitethernet52
exit
ip default-gateway 10.20.2.254
ip ssh-client key rsa key-pair
Your config looks fine. I did have a question about you default gateway...are you connecting to another switch, firewall, or router of some kind to get to this gateway and which port on this switch is it connecting to?
Once you switch to layer 3, you will need to set a default route in place of the ip default-gateway:
ip route 0.0.0.0 0.0.0.0 10.20.2.254
After you do this, if you do a sh run for the config, it will show ip default-gateway 10.20.2.254 even though the switch is in layer 3. It used to show the actual ip route in the config in previous versions of the firmware...this is cosmetic.
Richard
The only reason there is a default GW is so I can manage it from another site, this was only set when I saw problems with it, so defintely not related to the issue I am haivng
there s another switch (SGE2000p)connected to G51, which has a firewall connected to it, which is the default GW
Cheers
Hi Tony, if I had to make a guess, the switch doesn't know where to forward certain traffic therefore sending it out all ports. So my question would be, what traffic are you seeing, where does it originate and where should it go?
It is possible the switch isn't getting a MAC binding in the learning tables hence causing this behavior. Most likely it is something you have externally configured causing the confusion if that's the case.
One of the other problems aside from CAM table issues would be spanning tree. I doubt it's the problem but may be try to filter all BPDU.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I have to agree with Tom and would try his suggestions.
Richard
Hi all
It seems the problem was actually with the SGE2000 switch, that was forwardiing packets out all ports, which the SG-300 was then forwarding out all its ports.
I have updated the firmware on the SGE2000 which seems to have resloved the issue
interestingly there were also Catalyst switches connected to the SGE2000 and they weren't sending packets out all the ports, so it does lead me to think that there may still be and underlying issue with these swiches that had not quite been resloved yet
