Cisco SG-500, disable stacking(?) and why so many interfaces?
Erik Hennerfors
I'm not used to the Small Buisness switches from Cisco but i currently setting up a SG-500 switch and added mrtg for this switch, and there are so many interfaces, how come?
http://mrtg.obscured.se/test/
Is there a way to disable all the wierd interfaces? What dose (gigabitethernet4/1/27) even mean? 4/1/27 ?
Erik
Tom Watts
Hi Erik, the primary feature set of this switch is the stack feature and the 5/10 gig links. If that is not a desirable feature I'd implore you to look in to the SX300 features as it does not include either.
The port layout is pretty standardized, consider a Cisco Catalyst 3750 which would be something like GigabitEthernet3/0/2.
If you wish to disable the stack feature, you may. Admin -> Stack Management  then choose Standalone.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
