Cisco SG200-50 [version 1.3.0.62]-BPDU Guard feature not supported
support.info
BPDU Guard feature is not supported in version 1.3.0 of Cisco SW (SG200-50 ), I need to know please if it is supported in the lastest versions ? 1.4 for example ?
If so, which version is the most recommended ?
Switching, WANSwitching, WA
Thank you in advance.
Kind regards,
Martin Aleksandrov
Hi there,
BPDU guard is supported on Sx300 series switches and above. Sx200 do not support BPDU guard and this feature won't be implemented.
marce1000
 - Doubt whether small business series can do bpdu guard :
          https://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/10586-65.html#hw
 M.
Martin Aleksandrov
Hi there,
