Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 569 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5535 Views
  • 1 replies
  • 16 Helpful votes
I called the small business toll free phone number and gave them the serial number of the defective switch. They told me, based on the serial number, that I didn't by it from an authorized partner so it wouldn't be covered under warranty. I offered t...
ChandlerC by Level 1
  • 1017 Views
  • 1 replies
Hi, CURRENT SET-UPI have the Cisco Small Business switch CBS250-8PP-E-2G. The switch delivers power-over-the ethernet to two Cisco Small Business 240AC Access Points. I have disabled Smart Ports and Energy Efficient Network. USE CASENice to have feat...
If the left Orange light comes on for 10-20 seconds every 30-40 seconds when the connected device is off what does it mean? The right light is off all the time as it is probably a 10/100 connection.
SirBlot by Level 1
  • 1022 Views
  • 3 replies
Resolved! SG110 LEDs
We recently purchased some Cisco SG110-08 unmanaged eight-port switches.  I have a dumb question to ask (which is not addressed in the skimpy "Quick Start Guide," unfortunately).  My question involves the LED lights.  There are two LED indicators on ...
I am trying to configure some SNMP settings on my SF350-48MP switch but I get the error '% Wrong number of parameters or invalid range, size or characters entered'. The command is shown below:  snmp-server enable traps mac-notification changesnmp-ser...
Tamilore by Level 1
  • 1389 Views
  • 4 replies
Hello,I am new here and need help creating a default route. I have a SG350 configured as follows:I created 6 vlan and assigned them to ports (access/trunk etcIPv4 static routes).Then under IPv4 Interface I set IPv4 routing to enable and assigned IP a...
Hi  Was wondering if anyone has ever experienced or got any suggestions regarding an issue connecting to a SF300-24 switch running v1.4.11.2?Issue is that we have been happily connecting via SSH using RADIUS auth for sometime but we are now getting "...
Hello. I have a network like diagram below.I have to Vlans. Vlan 40 for IP phones and Vlan 190 for pc.In the first switch, there is no problem and the pc acquires the IP address without any problem.But, in the second switch the pc gets an APIPA.Can a...
I have some CBS250-24PP-4G-EU Switches (12 pcs.) and some CBS250-8PP-2G-EU Switches (6 pcs.)I get lost pings on each of the devices on some ports, at random times. I checked it with different ping tools for some weeks.Now I changed one switch, who ge...
I'm trying to use the DHCP relay feature, with no success. I've already tried on a SG300, on a SG350X and now on a CBS350, so clearly I'm letting something pass.Today I have the CBS350 in my lab. It's connected to the network (port 2, connected to an...
tschertel by Level 1
  • 4460 Views
  • 21 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
