Cisco SG250-08 Smart Switch Vlan configuration
Hi All,
I am planning to set up a Homelab and want to configure multiple VLAN's in a single switch port, switch will connect to the Intel nuc PC (ESXi installed). Can I use "Cisco SG250-08 Smart Switch" to achieve this?
in the switch feature it says L2+/L3.. but not sure if it supports it.
Thanks in advance.
regards
prateek
balaji.bandi
yes you can use trunk configuration it should be ok.
BB
balaji.bandi
BB
Thanks, @balaji.bandi , configured the trunk, and it's working as expected.
I could see Switch port mode to Layer 3, what is the use case of this ?
you can make the interface as a Layer 3 port-channel with a subinterface if you like to use a Layer 3 interface here.
you can extend the VLAN here with port-channel Layer 2.(that is what you are doing now)
BB
