02-12-2021 08:41 AM - edited 02-12-2021 08:42 AM
Hello!
Network:
I have H660GM router connected to switch on port TenGigabitEthernet1.
Router IP: 192.168.55.1
To the switch I have currently connected two computers:
Client A in VLAN R1:
Client B in VLAN CONFIG:
The problem:
I don't have internet access in any VLAN. Inter VLAN routing works fine.
Client A can ping Client B and vice versa.
Cllient A can ping Client B gateway and vice versa.
Switch can ping Client A, Client B and Router.
Client A and Client B can't ping Router.
The router works fine. When I connect router to the for example VLAN 5, computer connected to VLAN 5 has an internet access and can ping router.
Here is my configuration:
show run
config-file-header S1 v2.5.5.47 / RTESLA2.5.5_930_364_286 CLI v1.0 file SSD indicator encrypted @ ssd-control-start ssd config ssd file passphrase control unrestricted no ssd file integrity control ssd-control-end secret ! ! unit-type-control-start unit-type unit 1 network gi uplink te unit-type-control-end ! vlan database vlan 5,10,15,20,25,30,35,40,50 exit voice vlan oui-table add 0001e3 Siemens_AG_phone voice vlan oui-table add 00036b Cisco_phone voice vlan oui-table add 00096e Avaya voice vlan oui-table add 000fe2 H3C_Aolynk voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone voice vlan oui-table add 00d01e Pingtel_phone voice vlan oui-table add 00e075 Polycom/Veritel_phone voice vlan oui-table add 00e0bb 3Com_phone bonjour interface range vlan 1 hostname S1 username secret password encrypted secret privilege 15 ip ssh server snmp-server location secret ! interface vlan 1 ip address 192.168.1.1 255.255.255.0 no ip address dhcp ! interface vlan 5 name R1 ip address 192.168.5.1 255.255.255.0 ! interface vlan 10 name R2 ip address 192.168.10.1 255.255.255.0 ! interface vlan 15 name R3 ip address 192.168.15.1 255.255.255.0 ! interface vlan 20 name R4 ip address 192.168.20.1 255.255.255.0 ! interface vlan 25 name R5 ip address 192.168.25.1 255.255.255.0 ! interface vlan 30 name R6 ip address 192.168.30.1 255.255.255.0 ! interface vlan 35 name R7 ip address 192.168.35.1 255.255.255.0 ! interface vlan 40 name R8 ip address 192.168.40.1 255.255.255.0 ! interface vlan 50 name CONFIG ip address 192.168.50.1 255.255.255.0 ! interface GigabitEthernet1 switchport access vlan 5 ! interface GigabitEthernet2 switchport access vlan 5 ! interface GigabitEthernet3 switchport access vlan 5 ! interface GigabitEthernet4 switchport access vlan 10 ! interface GigabitEthernet5 switchport access vlan 10 ! interface GigabitEthernet6 switchport access vlan 10 ! interface GigabitEthernet7 switchport access vlan 15 ! interface GigabitEthernet8 switchport access vlan 15 ! interface GigabitEthernet9 switchport access vlan 15 ! interface GigabitEthernet10 switchport access vlan 15 ! interface GigabitEthernet11 switchport access vlan 15 ! interface GigabitEthernet12 switchport access vlan 15 ! interface GigabitEthernet13 switchport access vlan 20 ! interface GigabitEthernet14 switchport access vlan 20 ! interface GigabitEthernet15 switchport access vlan 20 ! interface GigabitEthernet16 switchport access vlan 25 ! interface GigabitEthernet17 switchport access vlan 25 ! interface GigabitEthernet18 switchport access vlan 25 ! interface GigabitEthernet19 switchport access vlan 30 ! interface GigabitEthernet20 switchport access vlan 30 ! interface GigabitEthernet21 switchport access vlan 35 ! interface GigabitEthernet22 switchport access vlan 35 ! interface GigabitEthernet23 switchport access vlan 40 ! interface GigabitEthernet24 switchport access vlan 40 ! interface TenGigabitEthernet1 ip address 192.168.55.2 255.255.255.0 no switchport switchport access vlan 55 ! interface TenGigabitEthernet2 switchport access vlan 50 switchport general pvid 50 switchport trunk native vlan 50 ! exit ip default-gateway 192.168.55.1
show ip routes
Maximum Parallel Paths: 1 (1 after reset) IP Forwarding: enabled Codes: > - best, C - connected, S - static S 0.0.0.0/0 [1/4] via 192.168.55.1, 00:09:07, te1 C 192.168.5.0/24 is directly connected, vlan 5 C 192.168.50.0/24 is directly connected, vlan 50 C 192.168.55.0/24 is directly connected, te1
show ip interfaces
IP Address I/F I/F Status Type Directed Prec Redirect Status admin/oper Broadcast ------------------ --------- ---------- ------- --------- ---- -------- ------ 192.168.1.1/24 vlan 1 UP/DOWN Static disable No enable Valid 192.168.5.1/24 vlan 5 UP/UP Static disable No enable Valid 192.168.10.1/24 vlan 10 UP/DOWN Static disable No enable Valid 192.168.15.1/24 vlan 15 UP/DOWN Static disable No enable Valid 192.168.20.1/24 vlan 20 UP/DOWN Static disable No enable Valid 192.168.25.1/24 vlan 25 UP/DOWN Static disable No enable Valid 192.168.30.1/24 vlan 30 UP/DOWN Static disable No enable Valid 192.168.35.1/24 vlan 35 UP/DOWN Static disable No enable Valid 192.168.40.1/24 vlan 40 UP/DOWN Static disable No enable Valid 192.168.50.1/24 vlan 50 UP/UP Static disable No enable Valid 192.168.55.2/24 te1 UP/UP Static disable No enable Valid
Router routers:
