Cisco SG300 trunk with 3com 4800G
jgrordinario
Our company currently have a 3com 2816 connected to a 3com 4800G through a trunk.  The 4800G connects to the PBX and to the ip phones/computers. We are currently using vlan1 (192.168.100.n) for data and vlan 3 (192.168.101.n) for voice , Ip addresses are being issued by a DHCP server. Each user has an assigned IP phone and it has an ethernet port that connects to each computer. This setup has been working properly until I purchased an SG300 and replaced the 3com 2816.
The ip phone is showing a bad gateway and the PC are getting an ip address of 192.168.101 (which is for voice). Theoretically it should work, but what is weird is, it seems the SG300 trunking with the 3com 4800G is not working. Is it possible that it is on ISL mode rather than dot1q?
I also saw its running RSTP, should I changed it to classic STP?
How do I fix this or what troubleshooting should i do?
The SG300 is configured as a layer 2 switch. Configuration for the trunk below:
interface gigabitethernet27
spanning-tree link-type point-to-point
switchport trunk allowed vlan add 3-4
macro description switch
macro auto smartport type switch $native_vlan 1
Joe
13 Replies 13
Tom Watts
Hi Jo, the SX300 supports only 802.1q, it does not support any Cisco proprietary protocol except CDP.
The gi27 has a macro negotiated. What I don't see is your vlan configuration. From this output, I know vlan 1 is your native and you have a vlan 3 and 4 for something.
Can you give any indication of what your LAN consists of in terms of native vlan and additional vlans and any indication of how this 4800G switch port is configured?
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
Thank you for your reply. Here is the vlan information from the SG300: vlan 4 is for the guest network used by our wireless AP.
vlan database
vlan 3-4
exit
voice vlan id 3
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
Below is the 4800G config and the port that connects to the 2816 right now since its having problems connecting to the cisco SG300
vlan 1
description datavlan
ip-subnet-vlan 0 ip 192.168.100.205 255.255.255.0
igmp-snooping enable
vlan 2
vlan 3
description voicevlan
vlan 4 to 4094
radius scheme system
server-type extended
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
interface GigabitEthernet1/0/46
port link-type trunk
port trunk permit vlan 1 3
broadcast-suppression pps 3000
undo jumboframe enable
poe enable
stp edged-port enable
Actually all of the ports of the 4800G has this configuration.
-Joe
Jojo, I don't understand the 4800G switch config so well, but what I see is bolded below. If permitting a vlan, it looks like your vlan 1 is tagged. So it would appear to me the SX300 is 1u, 3t,4t while the 4800G is 1t,3t. Does VLAN 4 exist on the 4800G? If so, is it the native vlan? What is the native vlan for the 4800G?
poe enable
-Tom
Hi Tom,
I also dont understand the 4800G configuration and I can't pull out the 2816 configuration. Anyway, the 4800G does permit the vlan 4, it's not on this config but the newer one has it. Native vlan for the 4800G is vlan 1
Jojo
Does this device support CLI?
Hi Isaac,
I think the 4800G support CLI , however I dont have access to it since its being serviced by an external IT vendor. I'll check with them if they will grant me temporary access.
it looks like your vlan1 and 3 are tagged on the 3c switch, and vlan1 is untagged on the sg300.  set the uplink port on the sg300 to General or Trunk, and make vlan 1 and 3 tagged.
Or set the 3com switch to trunk / 1 untagged, and 3 and 4 tagged.
Basically both sides of the uplink (sg300 and 3com) need to match.
You can test by setting one port on the sg300 access/untagged vlan1, and another access/untagged vlan3.  plug a pc into each access port, and verify you get the correct IP address on each vlan.
if that doesn't work, you can set 2 access ports on the 3com switch to vlan1 and 3 untagged.  use seperate uplinks for each vlan.  if that still doesn't work, there may be an issue with the dhcp server, or dhcp relay.
The sg300 has a full function CLI with the later firmwares, the first version 1.0.0.27  did not.
You need to go into Security > TCP/UDP Services page to enable telnet/ssh, or use a console cable.
admin guide has all the features and commands for the gui.
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
CLI admin guide:
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300_1_2_5.pdf
tag this post if it helps.
Dan
Hi Daniel,
I'll forward your suggestion to our external vendor.
Jojo
Hi Dan,
I just verified this morning that, 3com 4800 vlan 1 / data is untagged, vlan 3 /voice and vlan 4/ guest network is tagged.Cisco SG300 vlan 1 / data is untagged, vlan 3/voice and vlan 4/guest network is tagged. Their vlan is then the same.
Complete configuration below for the SG300
config-file-header
DGC-CoreSW
v1.2.7.76 / R750_NIK_1_2_584_002
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 3-4
exit
voice vlan id 3
hostname DGC-CoreSW
no passwords complexity enable
username admin password encrypted d033e22ae348aeb5660fc2140aec35850c4da997 privilege 15
username cisco password encrypted e8996464ca23106d9008f97d60c3892e0e133f01 privilege 15
snmp-server location "DGC Corp MDF"
snmp-server contact "Southwest Networks"
interface vlan 1
ip address 192.168.100.207 255.255.255.0
no ip address dhcp
interface vlan 3
name Voice
interface vlan 4
name Guest
interface gigabitethernet1
storm-control broadcast enable
storm-control broadcast level 10
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
macro description server
macro auto smartport type server $max_hosts 10 $native_vlan 1
switchport trunk native vlan 4
macro description ap
switchport default-vlan tagged
macro auto smartport type ap $native_vlan 4
interface gigabitethernet3
interface gigabitethernet4
switchport trunk allowed vlan add 4
switchport trunk native vlan 3
macro auto smartport type switch $native_vlan 3
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet28
ip default-gateway 192.168.100.254
Complete configuration for 3com 4800 below:
[4800G]display current-configuration
version 5.20 Release 2202P15, Release 2202P15
sysname 4800G
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
domain default enable system
telnet server enable
undo cluster enable
igmp-snooping
vlan 1
vlan 2
vlan 3
vlan 4 to 4094
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
local-user admin
authorization-attribute level 3
service-type telnet terminal
local-user manager
password simple manager
authorization-attribute level 2
local-user monitor
password simple monitor
authorization-attribute level 1
local-user swnet
service-type telnet
interface NULL0
interface Vlan-interface1
ip address 192.168.100.205 255.255.255.0
interface Vlan-interface3
ip address 192.168.101.205 255.255.255.0
interface GigabitEthernet1/0/1
poe enable
interface GigabitEthernet1/0/2
poe enable
interface GigabitEthernet1/0/3
poe enable
poe enable
interface GigabitEthernet1/0/5
poe enable
interface GigabitEthernet1/0/6
poe enable
interface GigabitEthernet1/0/7
poe enable
interface GigabitEthernet1/0/8
poe enable
interface GigabitEthernet1/0/9
poe enable
interface GigabitEthernet1/0/10
poe enable
interface GigabitEthernet1/0/11
poe enable
interface GigabitEthernet1/0/12
poe enable
interface GigabitEthernet1/0/13
poe enable
interface GigabitEthernet1/0/14
poe enable
interface GigabitEthernet1/0/15
poe enable
interface GigabitEthernet1/0/16
poe enable
interface GigabitEthernet1/0/17
poe enable
interface GigabitEthernet1/0/18
poe enable
interface GigabitEthernet1/0/19
poe enable
interface GigabitEthernet1/0/20
poe enable
interface GigabitEthernet1/0/21
poe enable
interface GigabitEthernet1/0/22
poe enable
interface GigabitEthernet1/0/23
poe enable
interface GigabitEthernet1/0/24
poe enable
interface GigabitEthernet1/0/25
poe enable
interface GigabitEthernet1/0/26
port trunk pvid vlan 3
poe enable
interface GigabitEthernet1/0/27
poe enable
interface GigabitEthernet1/0/28
poe enable
interface GigabitEthernet1/0/29
poe enable
interface GigabitEthernet1/0/30
poe enable
interface GigabitEthernet1/0/31
poe enable
interface GigabitEthernet1/0/32
poe enable
interface GigabitEthernet1/0/33
poe enable
interface GigabitEthernet1/0/34
poe enable
interface GigabitEthernet1/0/35
poe enable
interface GigabitEthernet1/0/36
poe enable
interface GigabitEthernet1/0/37
poe enable
interface GigabitEthernet1/0/38
poe enable
interface GigabitEthernet1/0/39
poe enable
interface GigabitEthernet1/0/40
poe enable
interface GigabitEthernet1/0/41
poe enable
interface GigabitEthernet1/0/42
poe enable
interface GigabitEthernet1/0/43
undo voice vlan mode auto
poe enable
interface GigabitEthernet1/0/44
poe enable
interface GigabitEthernet1/0/45
poe enable
poe enable
interface GigabitEthernet1/0/47
port access vlan 3
poe enable
interface GigabitEthernet1/0/48
port access vlan 3
poe enable
interface GigabitEthernet1/0/49
shutdown
interface GigabitEthernet1/0/50
shutdown
interface GigabitEthernet1/0/51
shutdown
interface GigabitEthernet1/0/52
shutdown
ip route-static 0.0.0.0 0.0.0.0 192.168.100.254
snmp-agent
snmp-agent local-engineid 8000002B034001C689AC41
snmp-agent community read public
snmp-agent community write private
snmp-agent sys-info version all
user-interface aux 0
authentication-mode scheme
user-interface aux 1 8
user-interface vty 0 4
Port 46 is the uplink port on the 4800 and port 27 is on the Cisco SG300.
Right now
Jojo
spanning-tree link-type point-to-point   <- point to point should be a STP link negotiation to a switch
switchport trunk allowed vlan add 4  <- VLAN 4 is tagged
switchport trunk native vlan 3  <- vlan 3 is untagged
switchport default-vlan tagged <- Vlan 1 is tagged
Your other point to point ports look like this- which is accurate to your description.
This can be your problem
-Tom
Hi Tom,
The Sg300 port 16 connects to our ASA Firewal port 3:
interface Ethernet0/3
nameif SWNET
security-level 100
ip address 192.168.101.254 255.255.255.0
How do i fix the issue?
The macro of the SX300 configure those settings on the switch port 16 based off the advertisements from the ASA. Can you verify the ASA native vlan is 1 and the additional vlans are tagged?
It looks like the native vlan of the ASA is vlan 3, hence the switch macro configured the port this way.
-Tom
Hi Tom,
I'm not familiar with the Cisco ASA yet, but when I made a search for the word "vlan" on the config file nothing comes up.
Jojo
