Cisco SG350 encounters LED light blinking continuously
Ponyeao2144
We encounter LED system light has blinking continuously on sg350
What is the cause? and How to fix it?
balaji.bandi
what LED ? system LED ?
Did you turn off and Turn on the device ? (chcek any console output)
if all tried still issue try factory reset and reconfigure, also try upgrade firmware to latest.
check the LED status :
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
BB
