10-07-2013 10:24 AM
Dear Friends
I wish you are fine .......... Kindly i have a question regarding Cisco Small Business 500 Series Switches ....... This series has reset button in the front panel ...... This button can be used to manually restart the switch or restore factort defaults configuration
Is their any way to disable the functionality of this button ???? The reason for that , I have a customer that will put the switch in unsafe & unsecure place and doesn't need any one to restore default configuration of the switch by mistake or on purpose
Waiting for your feedback
Best Regards
10-09-2013 04:34 PM
Hi Ahmed, there is not an option to disable this button. If it is absolutely impossible to lock the switch somewhere secure I'd recommend to use some tape and put over the button or secure something over the button so it's not easily tampered.
-Tom
Please mark answered for helpful posts
10-10-2013 03:26 AM
Dear Tom
Thanks for your replay
Best Regards
10-10-2013 03:11 AM
If you're happy to void any warranty, it might be possible to pull up the hood and cut some wires to that button ?
(Don't try this at home without adult supervision.)
10-10-2013 03:26 AM
Dear Brian
Best Regards
