Cisco SMB Switch SGE2000 ACL restriction
J_Vansen_S
Level 3
Level 3
hi,
I am running the SGE2000 as my l3 core switch with multiple inter-vlans.
have a customer requirement that needs to restrict eg. GUEST-VLAN10 to all other VLANS in the network.
Only allowing access to the internet.
It seems on the switch i am able to bind ACL to per port interface.
Please advise if this is possible on the SGE2000
Davidwagman1
Level 7
Level 7
Hi J Vansen,
Yes it is possible.
Before you bind the ACL to the port interface, did you create an ACE and ACL?
Best,
David
Hi J_Vansen_S
Yes, it's possible with your SGE2000 because it is a Layer 3 switch. With the command  “ip access-group (ACL-Name) in” you can block access to other vlan, for example
For example, let's say you have 4 VLAN's  and a WAN conection.
Vlan10  192.168.10.0/24 (GUEST-VLAN10)
Vlan20  192.168.20.0/24
Vlan30  30.0.0.0/8
Vlan40  192.168.0.0/16
Wan     10.10.10.0/30
This is the configuration:
ena
config t
   ip routing        -->Enable routing features
   vlan 10        -->Creates your Vlan10
     name GUEST-VLAN10
     exit
   ip access-list extended DenyVLAN-10                                     -->creates an ACL to deny the networks (VLAN's)
    deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255                    -->denies vlan 20
    deny ip 192.168.10.0 0.0.0.255 30.0.0.0 0.255.255.255                    -->denies vlan 30
    deny ip 192.168.10.0 0.0.0.255 192.168.40.0 0.0.255.255         -->denies vlan 40
    permit ip any any        -->allows access to the internet
    exit
  interface Vlan10
   ip address 192.168.10.254 255.255.255.0
   ip access-group DenyVLAN-10 in        -->associate the ACL to VLAN10
   exit
  interface Vlan20
   ip address 192.168.20.254 255.255.255.0
   exit
  interface Vlan30
   ip address 30.0.0.0 255.0.0.0
   exit
  interface Vlan40
   ip address 192.168.40.254 255.255.0.0
   exit
If this answer was satisfactory for you, please mark the question as Answered.
Greetings, Johnnatan Rodriguez Miranda
i had the same problem !!!
it works thanks
Hi Guys,
The new Sx300 and Sx500 have a supported CLI, i guess you can used CLI on the newer product, but the CLI above looks pretty similar to the 300 series CLI.
I know I can restrict a guest network,  as David Wagman suggested vua the GUI,  creating a ACE and ACL and then binding the ACL to the physical interface. (The switch filters on ingress of the packets)
The SxGE2000 does not have a supported CLI.  But if you look at the flow of the CLI above,  yep the only drawback is as I mentioned above, you add the access-list to a interface, not the VLAN.
regards Dave
