09-10-2022 03:32 AM
Hi Cisco Team,
I am using a Cisco switch C1000-8P-E-2G-L. When I insert the sfp module into the switch port and start the switch, the boot process stops at one level and I cannot access the switch (see image attached).
but when I remove the sfp module and reboot the switch, the boot process goes through and I manage to access the switch.
Please, Can you help me solve this problem?
09-10-2022 04:11 AM
Remove the SFP, boot up the switch. Once the switch boots up, upgrade the firmware to something more "recent".
09-10-2022 05:58 AM
- Ref : https://tmgmatrix.cisco.com/?npid=3002 . make sure the SFP is compatible with the device.
M.
09-12-2022 01:36 AM
I verified The SFP module. It is compatible with the device!
09-12-2022 01:58 AM
