07-04-2022 01:12 PM
Minimum 3 switch models required which fulfill the mentioned requirements which are:- 48 x 1Gb connections with the capability to tag each port to its own VLAN and trunk the VLANS through the switches to the ESXi server.
Solved! Go to Solution.
07-04-2022 01:17 PM
Are you looking for Enterprise or DC switches, Are you looking for high throughput?
First look at Cat 9300 - see if that fit ( I would go with Cat 9500 for better performance, if you have budget)
if you looking DC switch Nexus 9300 is a good choice for that requirement.
07-04-2022 01:17 PM
