Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 69 Views
  • 0 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5462 Views
  • 1 replies
  • 16 Helpful votes
In my lab, I have 2 Cisco SG350-10 switches connected to a Palo Alto 220 firewall. On my switches, I want to do layer 2 switching and routing on the firewall. Here is my setup: SG350-10 switch #1ports 1-3 VLAN2 set as access portsports 4-6 VLAN4 set ...
What is the CLI command to do the following: 1) set all the ports to have vlans 1-2, with vlan 1 (default) untagged, vlan 2 (VoIP) tagged 2) set the PVID of all ports to vlan 1 (is this necessary on sg350??), this is how our older sg300s are configur...
tommls by Level 1
  • 4423 Views
  • 4 replies
Hello to all, I have an issue with a Catalyst 5548, Rel. 17.6.04. After installing the IOS and installing the golden image the switch doesn't boot any more. The switch starts the boot sequence with  "initializing the hardware" stops afterwards and sh...
Hello all, sorry for the total newbie question but are the following messages anything to be concerned with? There are two switches on the stack. 1. CBS350-48T-4X, 2. CBS350-48P-4X. Thanks so much in advance!Stack3Master#18-Dec-2022 16:39:38 %PNPAGEN...
Resolved! SG300 Ciphers
I have looked every where and cannot find the command to show the ciphers this switch will accept. Does anyone know what the command is? Thank you for your help.
mmaness by Level 1
  • 1119 Views
  • 6 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
