CiscoSG500-52P vlan settings are copying to other SG500 switches
pg1151
I'm adding an SG500-52P switch to my network and have set it to L3mode. My network has an MS320 Meraki LAN switch that this L3 SG500 switch is uplinked to. Also, my network has 8 other SG500 switches in L2 mode uplinked to the Meraki MS320 switch. Once I connected this SG500 switch in L# mode and started adding VLANs to the switch, they copied over to my other 8 switches and messed up my network. I had to delete the added VLANs on my L3 SG500 switch and my L@ switches so the network would be working properly again. Why did this switch copy VLANs to the other switches and how do I keep this from happening again?
pg2241
Any reply please???
mridsing
Thanks for your post,
Regarding the issue it needs to be checked over remote session.
Kindly request you to open a service request by calling our frontline team.
Phone link:- https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Settings that needs to be checked.
In both SG500 L3 and L2
-> GVRP is enabled/disabled (Needs to disabled)
->Tagging done on uplinks ports in L2 and L3 switches to Meraki.
Mridul
Cisco SBSC TAC.
