11-08-2015 06:12 AM
The administration guide seems to indicate that all of the energy saving modes can be turned off on the SG300 and the SG220 series switches. I could not find an online configuration emulator to test this since what is on the website is a non-functional mockup. Is this correct that the ports can be configered to be always on at full power ?
i have several ethernet gigabit MOCA 2 modems that will lock up if the switch port does not operate as non-green and non-EEE so i need to confirm from someones experience with the switch or can test the configuration.
I would use an unmanaged switch, but they all seem to implement EEE or Green and, of course, no way to turn it off.
Thanks for you help,
Frank
11-11-2015 10:21 AM
I believe you can.
These are the Green Ethernet settings on my SG300-10:
11-11-2015 01:38 PM
Thank you for your helpful reply.
i think so as well, but before i purchase a switch, i am looking for confirmation from either Cisco or someone in the same situation.
