06-25-2011 12:28 PM
I have a cisco 2921 router connected to a cisco sg300-52 L3 switch. The switch is configured with several subnets and I need to use the router for DHCP. I setup DHCP on the router to assign addresses to a subnet on the switch but cannot get it to work.
Router:
gateway to LAN is xxx.16.10.1
ip dhcp excluded-address xxx.16.0.1 xxx.16.0.9
ip dhcp pool data
network xxx.16.0.0 255.255.254.0
default-router xxx.16.1.1
dns-server xxx.16.1.202
domain-name mydhcp.com
Switch to router xxx.16.10.2
Network on switch for DHCP is xxx.16.1.1
when I do a sho dhcp spool I see the addresses
any idea?
06-27-2011 09:49 AM
Hi Gary,
I am wondering if you need to vlan and trunk your ethernet interface going to the SG300 switch?
See a example i used on my old 2821 router; usually on my 300 series switch I leave vlan1 untagged and leave vlan 100 tagged on my trunk port.
Here is my router config , notice that I tagged the interfaces going to my ethernet switch. Works ok.
GigabitEthernet0/1 is the interface trunked to my switch.
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp excluded-address 10.2.1.1 10.2.1.10
ip dhcp pool data
import all
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 209.18.47.61 209.18.47.62
ip dhcp pool Voice
network 10.2.1.0 255.255.255.0
default-router 10.2.1.1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.20.1 255.255.255.0
ip virtual-reassembly in
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.2.1.1 255.255.255.0
hope this helps
regards Dave
06-27-2011 06:41 PM
David,
Thanks for the response. When I finally found where to download the sg300 maintenance manual I found where I needed to setup the switch as a DHCP relay for the various subnets on the switch.
06-27-2011 06:42 PM
David,
What does the “import all” command do in the DHCP?
06-27-2011 11:55 PM
Hi Gary,
My config assumes that the Sx300 series switch is trunked to the router. I guess you are just relaying dhcp requests via vlan1 to a router.
Import all does the following, it imports Dynamic Host Configuration Protocol option parameters into the DHCP server database.
regards Dave
06-28-2011 07:42 AM
David,
Thanks, I was reading up on that. Last thing is to setup the Firewall in the 2921 router, any examples on that?
