08-25-2013 01:39 AM
hi
I have SGE2010 switch in layer 3 mode and im unable to assign IP addresses in second VLAN 2.
My setup
Port 1: TRUNK , VLAN 1 and VLAN 2 --> connected to Cisco 887 FE3 Trunk with VLAn 1 and VLAN 2 and DHCP pool for VLAN2
Port 2: TRUNK , VALN1 and WLAN2 --> Cisco Aironet 1040 LAN WIFI VLAN 1 and Guest WIFI VLAN2
Port 3: Access , VLAN1 Windows DHCP server for VLAN 1 subnet
My LAN WIFI clients can get IP from Windows DHCP server for VLAN 1
My Guest WIFI clients on VLAN 2 cant get an IP from the Cisco 887 router on VLAN 2.
I did try turning on DHCP relay etc but didnt make any difference.
Can anyone give me some pointers on wat im missing ?
Thank you
08-25-2013 05:40 AM
Hi, if the symptom is that when you assign an IP address to vlan 2 the switch "locks up" then the reason is because the vlan 1 did not have an IP address assigned by user.
To fix that, you'd need to add an IP address for vlan 1 as you like then try to make an IP for the additional vlans.
-Tom
Please mark answered for helpful posts
08-25-2013 07:31 AM
hi
The switch doesnt lockup ,I have assigned IP on Vlan 1 and Vlan2 interface.
The switch doesnt pass the DHCP requests for VLAN 2
08-25-2013 07:34 AM
Hi, yes, DHCP relay would be the correct configuration and most likely need option 82. Your DHCP server would also need to support it.
-Tom
